its my brother old pc what is prebuilt.like 4 -6 years old.i want replace psu with newr one but cant figure how to remove it..
that black box is place where hdd 2 bays and psu are located..sadly all hdd bays are 3.5 and that why i used tape to install ssd..
https://linustechtips.com/topic/1151660-how-hell-i-remove-this-power-supply/
Remove screws from the power supply (see 2nd picture, there's 1 out of 4 screws removed) then open side panel and unplug the cables going to the motherboard and various components (ex hard drives)
Slide out power supply (if there's a shroud over, there's gonna be some clips or screws locking the shroud over the power supply compartment.
Could be able to get to the power supply from the side of the case that doesn't have a window without having to remove the shroud
https://imgur.com/VZak7pv
Remove the screws
same thing, it should be another screw upwards
now slide off the pannel
Now you should have access to the psu, but remember to detach also the connectors from the motherboard (access to it by removing the other side panel)
