PC Upgrade: Help needed on setting priorities
Solved by Metallus97,
7 minutes ago, Charlus said:Or is my setup too old and I should first refresh the CPU and then upgrade the GPU ?
Yes! ‚Tis is a pretty old CPU and platform. Idd recommend going
MSI B450 A Pro Max
AMD R5 3600
some 3200Mhz Cl16 2x8GB Ram
Wich PSU do you have and do you have an SSD?
The 780ti isn’t the fadstes anymore but should be ok for the time being untill you can get a new GPU. Medium 1080p should be possible
