So im looking for something to put on my wall.
I'm aware of Aurora Nanoleaf but the 2 problems i have with them are 1 - price but a lesser issue, but they are a bit pricey for what they are and main issue 2 - the diffusion you can see from the sides
see how they are brighter on the sides? for 200 quid that would seriously annoy me. Maybe if they made a v2 without this issue.
So i also saw Cololight Pro, they look like they don't have this issue but i cant figure out if they do, how they stick to a wall i dont want that stand crap.
If anyone knows any other ones or recommendations that would be great thanks :)
https://linustechtips.com/topic/1151517-rgb-wall-decor/
I always do some kind of diy in my led strips. I just use some acetate, paint the inside white then make some kind of diffuser with it.
#PoorButWantsRGB
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1151517-rgb-wall-decor/#findComment-13265054
#PoorButWantsRGB
thats actually really cool! is there some kind of product that would allow syncing such a diy solution with a motherboard header?
Folding stats
Vigilo Confido
https://linustechtips.com/topic/1151517-rgb-wall-decor/#findComment-13265090
i reckon if you counted how many led's are in each of your man-made 'squares', you could program each one to be a different colour etc. pretty easily if they are addressable.
something like icue would easily do it but it would be hard to change colour scheme kinda as you have to select each pixel individually
https://linustechtips.com/topic/1151517-rgb-wall-decor/#findComment-13265116
Most of them use the same 4pin RGB header as is on some motherboards and do work with ASUS Aura etc so if you run the connector (they mostly have seperate power and lighting control) into your PC case you could use your motherboard if it supports it
PC: Ryzen 9 5900x | RTX 3080Ti | Asus Prime B450-PLUS | ASUS ROG Strix 1000W Gold | 32GB Corsair Vengeance 3200MHz RAM | 512GB NVME SSD + 2TB NVME + 6TB WD BLACK | Windows 10 Pro + Windows 7 Ultimate
Laptop: MacBook Pro 15" 2018 | i9-8950HK | Radeon Pro 560X | 32gb RAM | 1tb SSD
iPhone 13 Pro Max | 256GB | iOS 16.5 with Dopamine 2 + Trollstore 2
https://linustechtips.com/topic/1151517-rgb-wall-decor/#findComment-13265123
