2070 Super low core clock speed
Solved by Buksi,
Problem solved! Downloaded the latest driver from guru3d, used DDU then reinstalled the driver from guru3d and now it's working at 1935mhz! I had the same driver installed but on GPU-Z it said I had a DCH version (don't ask me what it means). Now that DCH is gone and it's working as intended! Super happy, although it came with a pretty loud coil whine which I'm not sure if it's harmful in any way but yea, I don't hear it if I'm gaming so yea...
Featured Topics
DungFu ·
Posted in Troubleshooting3 -
3
JingleJaxson ·
ulookuglynoob ·
Posted in Phones and Tablets0 -
nick name ·
Posted in Networking2 -
2
2
2
6
8
play_circle_filled
Latest From GameLinked:
Are you excited for Doom: The Dark Ages? - Gamers 2 Gamers
