Hi guys! My budget is roughly around $500 - $700 USD (Got my financial aid check, need a decent laptop for word processing / school and mild-gaming on low).  I will eventually reinstall windows 7 64 proff on it, I just cannot stand 8.  Personal preference sorry :(  (If, ofcourse the drivers will work, etc)
First one is:
http://www.newegg.com/Product/Product.aspx?Item=N82E16834312829
Second is:
http://www.newegg.com/Product/Product.aspx?Item=N82E16834686004
It does look like the avatar is way thinner and looks sleek as heck, but is the extra 200$ even worth it? Sure, the ssd is nice... but I'm looking for a laptop to just lay down in bed with and play (Continent of the Ninth), Marvel Heroes, Path of Exile, or whatever on Medium Settings ofcourse.  Not looking for a powerhorse or anything special, just something that can play these games on low to medium with 30+FPS.   Hard drive space isn't even a issue, I'm fine with like 100GB... I probably still won't even use 50% of that alone, but I guess it's nice to have more space.
Anyways, thanks for reading, any insight and advice would be appreciated!
Also, maybe if there is a laptop that can fit my needs for even less than 499, that would be ideal...
https://linustechtips.com/topic/115035-help-me-choose-between-these-laptops/
If you're looking toward the top end of your budget I'd go with this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16834314417
Are you going to be carrying it around much?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
i approve of your picture pikachu brethren :3
Specs
Not much I'd say, but I would like to carry it in my backpack or in a laptop case while walking to class.  (Dependant on size, lol)
I'm not sure if I would use a touch screen to be honest, could that price get lowered w/o a touchscreen by chance? That 128gb sdd is a perfect find for me though.
Edit: Hmm, how far can that INTEL HD 4000 graphics go?
Edit2: aww Crap, just checked the screen size, looking for atleast 15. (maybe 14) Sorry forgot to tell you guys
Depends how long you want you battery life to last....a dedicated card will suck a lot more juice.
I can play SC2 on my 4000 with low settings. But on a 13.3" screen with 900p it still looks good.
If you want to go with a cheap, portable ultrabook you'll have to sacrifice quite a bit.
The non touch in your price range for that model is the 11.6" not the 13.3".
I prefer the Lenovo one based on the spec.
but of course the other one is an ultrabook which is nice too.
Im not sure about eh ultrabook though. I never heard the brand before.
MB :MSI Z77a G45 | Proc: I5 3570K (Stock) | HSF : CM 212X turbo | RAM : Corsair Vengeance 8GB (2X4GB) | VGA : MSI GTX 660 Twin Frozr | PSU : Corsair GS600 | Case : CM Storm Enforcer | Storage :  OCZ Vector 128GB, WD Blue 500GB , Samsung 840 Evo 120GB, WD Blue 1TB
I'd go with the lenovo one.  Not sure if I'm just an idiot and that other laptop brand is huge, but to me it's unknown, so i wouldn't go with it
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
http://www.newegg.com/Product/Product.aspx?Item=N82E16834231455
I would say you go with this one. My friend has one, it's decent. Spec is good, quality is good(aluminium construction), and it's Asus, you can't go wrong with that.
-Desktop: Asrock H81M-HDS R2.0, Pentium G3258 4.2 ghz OC, Palit GTX 750 ti StormX, Kingston HyperX Fury 1600 4gb, Seagate Baracuda
-Laptop: MSI GE620DX, i72670QM 2.2 Ghz, 8GB 1333mhz Ram, GT555M 2GB DDR3.
-Gaming peripherals: Razer Deathadder 2013, Superlux HD 681 Evo Razer Goliathus Control Medium sizeCm Storm Quickfire TK white edition.
