Last month I bought a 2060 super from zotac (specifically the AMP or the dual fan varient). However it became apparent really quick that the card is making a lot of noise!! I have it set on a very aggressive fan curve because my case is a mini itx one and the air flow is not really good. The card stays at around 67-71 while playing Jedi Fallen Order on Epic settings, do you think that by reducing the fan speed and lettimg the card go up to 76 or close to that will be fine? What do you think is the max temp that my card should hit without me worrying??
Thanks for your time!!
https://linustechtips.com/topic/1149099-amp-2060-super-temps-issue/
Please don't triple post.
76 is fine. Anything below like 83 is fair.
8 hours ago, NoGanksEric said:
Your temps are really good for that kind of Scenario
Lowering the fan speeds to maybe achieve at most 79°C should be fine.
Tho tbh everything below 95 is generally safe temps. Tho you shouldn't push that far if you don't have to
Ohhh really? I thought that it was really bad, then I will lower the fan speed a little bit, thanks for the informationn!!
