Surround with Multi BT Speakers
Bbas
Hello all,
Have anyone here read/know about using multiple inexpensive BT speakers with a pc to create a surround system. Or even two soundbars (one front, another rear)?
I was thinking to get 2 budget decent sound bars total cost 300$ and use the BT to frankstein a surround system for PC.
Reasons:
A. Cost
B. Cables
The front bar should be placed under my screen, about 80 cm away from me.
The rear bar, I would place it above the door behind me, so it would be higher than me and directed diagonally about 2.5 meters.
Much appreciated!
I don't think there's any native support/drivers/setup for multichannel bluetooth, but you might be able to do it with multiple transmitters like this.
