1650 Super fan issues?
Go to solution Solved by Statik,
Do you have a fan curve set?
So, I've had my 1650 super for a while now and for some odd reason, the fans like to ramp up and then turn off immediately at random intervals or times during different days - usually this is either in a game (not really utilising the GPU to the point where they turn on at max) or sitting idle so I'm asking anyone who has the same experiences and know the answer to this issue - for in-depth description of my graphics card, it's a Gigabyte GTX 1650 Super Windforce (not sure if this is happening to other 16 series, same manufacturer or is just a general issue with my graphics card).
Edit: I know that most of you would answer back with "a graphics card will heat up anyways" or something like that so the fans will turn on though they only do so for basically a single second and then doesnt turn back on until I play an intensive game or even up to the point where I finally turn my PC off. My old 1050 ti didnt do this so I'm thinking it may be an issue with my graphics card by itself.
https://linustechtips.com/topic/1148730-1650-super-fan-issues/
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1148730-1650-super-fan-issues/#findComment-13243598
5 minutes ago, Warren Hanson said:
Is there any good software (except from msi afterburner and other similar software) that is good for setting a fan curve where I don't have to go into bios to set it manually?
Just for gpu?
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1148730-1650-super-fan-issues/#findComment-13243617
Just now, Warren Hanson said:
It would be good for other fans as well alongside GPU
You may want to try software from this post
I did use it and it’s really good.
                                          WHIRO
https://linustechtips.com/topic/1148730-1650-super-fan-issues/#findComment-13243621
