Do you plan on overclocking? The fans that come with the R4 are also pretty nice.
https://linustechtips.com/topic/114859-air-cooling-help/#findComment-1535461
aLSO FOR NOSIE REASON GO FOR THE NEW NOCTUAS BLACK COMING SOON:D
We are not going to have black Noctuas
I'm in the process of building a computer. I have an MSI z87-gd65 with an i5 4670k in a fractal r4 case. I was wanting to know what would be a good CPU fan to keep it cool? Also do you recommend changing the fans that come with the case?
NHD14, PHTC14PE, Dark rock pro 2/3. Any of those three heat sinks are silent and perform well.
The stocks R4 fans are plenty quiet, if you need more air flow in your case then consider replacing them with silence optimized fans that have higher rated air flow or static pressure.
Error: 410
https://linustechtips.com/topic/114859-air-cooling-help/#findComment-1535462
Last year at CES they said first quarter next year which is the first 91 days of the year.
https://linustechtips.com/topic/114859-air-cooling-help/#findComment-1535476
Those are industrial grade fans
you do not want industrial grade fans
They will release gray(?) or different colored cut down versions. No black.
Error: 410
https://linustechtips.com/topic/114859-air-cooling-help/#findComment-1535489
Where are you shopping/located?
https://linustechtips.com/topic/114859-air-cooling-help/#findComment-1535635
Instead of buying a high-end air cooler, you could drop another 20 or 30 dollars and get a good closed loop water cooler.
Such as a Corsair H80 or H90 for around 80-90 dollars. Or the H110 or 105 for 100 - 120.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181060
CPU- i5 4670K CPU Cooler- Corsair H90 MB- MSI Z87 GD-45 RAM- 16gb G.Skill Ripjaws Case- NZXT Phantom 530
PSU- Corsair CX750M Cooler- Corsair H90 Boot Drive- Samsung 850 Evo 250GB
Storage-WD 1TB Blue Storage- Seagate 2TB
https://linustechtips.com/topic/114859-air-cooling-help/#findComment-1536035
Internet, but I live in the Dallas Fort Worth area
212 Evo http://pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/114859-air-cooling-help/#findComment-1536697
