Hi guys, I'm new to the Linus Tech Tips forum here, and I have a few questions.
I was looking into buying a PC, but hen I thought that it might be a good idea to try and build one for the first time. I was just wondering if anyone has any advice to give to a newbie PC builder? Thanks!
https://linustechtips.com/topic/114802-building-my-first-pc/
Take you time. If you can build a Lego set you can build a computer.
The only "hard" part is the thermal paste. If you can call it hard.
Watch a few of Linus's builds and you'll know everything you need.
Don't force things if they don't fit.
Take time with cable routing.
Use antistatic straps if you have carpet.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/114802-building-my-first-pc/#findComment-1534682
Welcome to the Forum. :D
You're going to love it here.
Just kidding get out while you still can!
My first tip is that you should make sure that all your components are plugged in. One time I forgot to plug in my HDD for a new build and it wouldn't boot.
https://linustechtips.com/topic/114802-building-my-first-pc/#findComment-1534686
Welcome. You came to the right place.
If you know anything about parts you can go here and make your build. Then post it in the New Builds and Planning section and you will get good criticism.
"When in doubt, don't take your wallet out." - Dad
† TTCF Member †
https://linustechtips.com/topic/114802-building-my-first-pc/#findComment-1534688
Welcome to the forum!
There is lots and lots of information floating around this forum. I would suggest you check out some of the sub forums and get an idea for what you what, then post your ideas and plan in the "Build Planning" forum so we can offer advice.
Also, http://pcpartpicker.com/ This place is your friend.
https://linustechtips.com/topic/114802-building-my-first-pc/#findComment-1534696
Cool, thanks! I have heard of www.pcpartpicker.com, but have never actually gone there. I'll go check it out right now. Also, I'm looking to budget somewhere around $1,000.
Read http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/. It outlines all the information that will help people make recommendations.
https://linustechtips.com/topic/114802-building-my-first-pc/#findComment-1536542
