hey guys, I have a few questions regarding the p400a case. The first question is; Would I be able to control the led fan lights with the b450 tomahawk max? or would I just have to use the rgb fan controller. The second question is; what would be the best mounting/configuration for my cpu cooler (hyper 212 black edition) on my motherboard for cooling in this case? Any help with this would be great!
https://linustechtips.com/topic/1147351-p400a-help/
What do you mean by that??
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1147351-p400a-help/#findComment-13232256
You will most likely need an adapter for the rgb to be mobo controlled. I had to do that with my P400TG and my P400S cases.
As for the cooler, it only goes on one way. But just make sure the fans face the front and the rear of the case. I attached an image of my case with a hyper 212 Evo installed.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/1147351-p400a-help/#findComment-13232638
What kind of GPU cooler do you have?  Is it blower style or open air like most 3rd party cooling solutions?  IF it's open air I would suggest 3 front intakes that come with the case, and if you have any extra fans, the top front as intake, while the top back and exhaust are exhaust.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/1147351-p400a-help/#findComment-13232739
Fan near the ram, blowing air through the cooling tower towards the rear case fan.
For more pics, see the RGB Build Post 2019 in my signature.
https://linustechtips.com/topic/1147351-p400a-help/#findComment-13233997
