what are you using it for? id personally get less ram, cheaper cooler, and an ssd but thats because i dont use any programs that can use more than 16GB of ram and i dont see myself ever getting a top of the line cpu
https://linustechtips.com/topic/1147295-first-pc-build/#findComment-13231373
Don't use the GT 730, use the integrated graphics.
No SSD? System will be slow as hell.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1147295-first-pc-build/#findComment-13231406
There are better CPU choices out there, and that motherboard doesn't allow overclocking, which also makes that AIO kind of worthless, as your CPU will be stuck at stock speeds.
That GT 730 is probably slower than integrated Intel graphics.
Also, you need an SSD, at least for your OS.
What exactly would be the use case for your PC?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1147295-first-pc-build/#findComment-13231418
Is there a ceratin way I can check if you can overclock any certain motherboard?
https://linustechtips.com/topic/1147295-first-pc-build/#findComment-13231431
In the case of Intel, only Z series motherboards allow overclocking. For example, for a 9600KF, you would need either a Z390 board or a Z370 with a BIOS update.
https://linustechtips.com/topic/1147295-first-pc-build/#findComment-13231447
1 hour ago, bitfly said:
This is what I'm looking at for my first PC, does it look like anything is missing?
looks good so far, however for 160$ you can get a 1650 super, which will destroy the 1050 ti. Even if you don't use it for gaming, if you sort on PC Part picker there is one for literally a dollar cheaper, so why not?
PC:
i5 8400 - RTX 2060 - Strix B360-I - Thermaltake 240mm AIO - 16GB Vengeance RGB PRO - CRYSTAL 280X - HD Plex 400w AC/DC Converter
CUSTOM KEYBOARD:
Gmmk Pro  - Gateron ink Black v2 lubed and filmed - GMK Red Samurai - PC plate - Zeal stabs
DAILY TECH:
Samsung Gear s3 Frontier Smartwatch - Galaxy A70 - Bose QC Earbuds - Bose SoundLink Wireless - Ultimate Ears Wonderboom
https://linustechtips.com/topic/1147295-first-pc-build/#findComment-13231731
