NZXT HUE is not bad...
Case:NZXT H440   CPU:3570k @ 4.4ghz   Cooler:Prolimatech Megahalems w/ ap121 p/p  GPU:Gigabyte Windforce GTX 770  RAM:Crucial Ballistix Tactical Tracer 16gb 1600mhz  Mobo:Sabertooth Z77     PSU:Cooler Master Silent Pro M 700w   Wheel: Logitech G27 + joystick as handbrake Asus DGX 5.1        Mouse: Corsair M65     Keyboard: CM Storm Trigger Cherry MX black  Headphones: ATH-M50s    Phone: Nexus 5 32GB  Earphones: Sennheiser CX 400ii    SSD: 120gb 840 evo  HDD: WD Enterprise 2TB    AMP&DAC: Schiit Stack.
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1532320
but is it RGB
Yes, it even has various lighting modes, like pulsating etc.
Watch a video on it on Youtube.
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1532331
Ive got the NZXT Hue... Not sure whether to install it or not because Im afraid that the adhesive will be crap (mixed reviews) and I wont get my money back
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1532355
just make sure the area youre sticking it to has been cleaned
it might come off after a cople months, but you can always get some better double sided tape and restick it
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1532411
Is it worth keeping though? like are the LEDs strong and nice?
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1532415
i think i go with The NZXT HUE it looks very good and i can get it in Denmark so yeah. Thank you very much
its great for RGB but dont get it for white lighting
i made that mistake because i wanted to get some white light, but having R G and B does not make white...
disappointing
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1532416
Stick it down with blue tack or just hold it somewhere and light it up to see where the best place to put it is
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1532453
disappointing
I think I will mostly use Red
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1532463
Do you reccomend the Hue?
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1532467
hmm you mean using rgb or just single coloured light strips
RGB is good if your interested in multi coloured lighting however it is or could be cheaper than buying two strips that are different colours
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1532485
Well some people have told me that the quality of the HUE is hit or miss and I did pay 60 USD for it because thats sweden for ya, anyway, if it were to be a good unit would the RED LEDs be strong but not take atention away from my components?
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1532502
try out first savedadingo :D
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1532510
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1532520
yeah the rgb is great
very even lighting, plus you can adjust all the levels to your liking
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1535738
Adhesive is pretty sucky but Just use double sided tape or even regular packing tape taped to itself instead. I've got one in my rig with no issues.
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1542418
I just ordered the corsair link RBG lighting node, only the lighting node tho @ 29.99, as i already have a H100i,
and a 860i, so there was no point getting the additional corsair link kit when i can plug it directly into my
H100i or my 860i depending on how i want my cable management to work. haven't seen much on these
lights, so they could be super good, or they could be super bad, but was willing to find out @ 30 bucks eh.
The Nzxt hue's look great, especially the compatibility with cases look's to be really good with them, i've
seen people really raving over how they fit surprising well for some corsair cases, like they were made for them.
the only thing that turned my off about the nzxt hue was the front light controllers, i have a corsair 750D, and the
idea of having the nzxt hue stick out the front of my case like a sore thumb, i couldn't deal with, some would argue
that the aesthetics of it really match that of the 750D, but even still, for my taste it doesn't match it enough.
But yeah, those are my 2 cents on the matter, enjoy the lights!
https://linustechtips.com/topic/114642-rgb-led-strips/#findComment-1542760
