Help decide laptop for school
Solved by genexis_x,
7 hours ago, Tran said:might bump up the laptop budget to $700
there's no need to, just choose from the options above
7 hours ago, Tran said:do you have any recommendations for one that range that has USB2.0/3.0 ports?
Refer to options above, they have (except Ideapad 730s)
ShayOh ·
Posted in Troubleshooting1 -
Newbietobe5467 ·
Posted in Troubleshooting2 -
1
robjt ·
Posted in Troubleshooting16
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
