19 minutes ago, TheFluffyFish said:
Can using a Power Supply as an extra exhaust decrease temperatures?
Is this safe to do and has anyone tried this?
It would but it's difficult to know how effective that is, and it's safe as long as you have a decent power supply that isn't being overloaded
Quote or Tag people so they know that you've replied.
The original ATX design was such that the PSU was supposed to do this. So yes, it's fine. The side effect however is the PSU will get warmer if you stress the hardware and this will decrease the PSU's overall effectiveness. But unless you got a PSU that just makes enough power, this isn't something to really worry about.
back then PSU's had 2 fans
CPU:  i7 9700K / CPU Cooler: bequiet! Dark Rock Pro 4/Motherboard: Gigabyte z390 Aorus Pro Wifi/ RAM: 2 x Ballistix 8GB  DDR4
GPU:  ASUS ROG STRIX  RTX 2070 SSD:  ADATA XPG SX8200 Pro 1TB NVMe / HDD:  3TB WD 30EZRX
PC Case:  CM H500P Mesh White / PSU: Corsair RM850i -850w Gold  /Monitor :LG CX 55 + S27B970D
DAC: Audioengine D1 /Speakers : Focal Bird 2.1 /Headphones: Sennheiser HD 380Pro / B&W PX
 PC Part Picker
Actually most of them had 1 smaller Fan, a 6cm one instead of the usual 12cm used in today's PSUs.
you maybe right since it was cheaper to just have one fan
and it is still a viable option in ATX2.2
Quote
The ATX Specification offers two options for venting between the power supply and the system interior:
• The venting shown in Figure 8 provides the most effective channeled airflow for the power supply itself, with little regard for directly cooling any system components. This venting method is nearly always used in conjunction with a fan that exhausts out the rear of the power supply.
• The venting shown in Figure 9 allows designers to more directly couple the power supply airflow to system components such as the processor or motherboard core, potentially cooling all critical components with a single fan. Both the power supply fan location and direction may vary in this case. The trade-off is usually one of reduced system cost versus narrower design applicability
I wouldnt prefer this method though specially with high end systems  since PSU fans are one the most probable components  that will fail first in a PSU , so no need to overload it
 PC Part Picker
The problem is getting the PSU to actually do it. (I.e run constantly or according to the needs of case air temp) PSU fan controllers are independent of the motherboard, and have different heat controls.  Many PSUs could in theory do it but won’t in practice.
Actually, they had 80mm fans and the more common fan used today is 140mm.
What case?
What PSU?
It depends, and yes, I usually build systems like this, with using the cpu-fan as a separate intake as well. But primarily they're not designed for gaming or have to face extreme overclock.
If its bottom mounted it will just be fighting with your axial or blower GPU.  Best to allow the bottom mount to be used as its own intake and exhaust for the PSU if it has that option (grill on the bottom) if not I would DIY the bottom so I could still correctly bottom mount my PSU.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
