Is it legitimate to create my own operating system?
TsmDan Studios and Computer Epicenter take absolutely no liability or responsibility for any damages caused by operation on your device. If you damage something, don't blame it on me. If I break something, it's not my fault.
WARNING: Opening a laptop will immediately void any warranty on that laptop
WARNING: Your price for Builds will increase twofold because of insurance
https://linustechtips.com/topic/1145951-operating-system-help/
If you have the technical skills to do it, sure you can.  What use case do you have for it?  Commercially you are not likely to move it due to competition with Windows and iOS.  In the free market you have Linux already and there is not really a need for a new distro.  Just take any existing one and edit the kernel to your needs.
You would probably need a compatibility layer like Wine to make anything run on it other than your custom software.
https://linustechtips.com/topic/1145951-operating-system-help/#findComment-13220781
1 minute ago, Mira Yurizaki said:
You can create your own OS. But something with more features than say a simple DOS-like OS is generally beyond the scope of a single person.
okay I'll recreate MS-DOS and then give it to IBM
https://linustechtips.com/topic/1145951-operating-system-help/#findComment-13220804
Guest
