PWM or nah
Go to solution Solved by homeap5,
Answer is in your question. :)
I just bought the Silverstone RL06 and I am in love with it.
I had the Phanteks Enthoo Luxe previously which I hated so very much.
There are a few things I wish they had not cheaped out on like the fans. The fans are only 3 pin and not PWM. Do you guys think I should change the fans to PWM fans or do you think it doesn't matter?
I don't really care about the noise so them running at full speed is not really an issue for me.
https://linustechtips.com/topic/1145856-pwm-or-nah/
