Posted January 16, 2020 Hi everyone, While playing RDR2, I have a sort of horizontal core clock graph. But sometimes, like seen on image, it downclocks briefly. I can also feel the stutter ingame when this happens. I don´t think it is the CPUs or GPUs fault. Since CPU temp is 71C and GPU is max 84C. What else could be causing this? Thanks for the help! My specs: MOBO: Gaming Plus B450 CPU: Ryzen 5 2600x CPU Cooler: Hyper 212 GPU: Sapphire Pulse RX 5700XT Monitor: Asus mg28uq Case: Cooler Master MasterBox Lite 5 (3 intake 1 exhuast) RAM: Corsair Vengeance 2x8 @3000Mhz SSD1 (OS): Samsung EVO 500GB SSD2: Kingstone SSDnow 120GB HDD1: WD 3TB green PSU: Corsair RM650x Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 16, 2020 Author I found some more information. On task manager, you can see how when this spike occurs, there is a drop in VRAM usage also, along with a tiny spike on Copy. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 16, 2020 3 hours ago, Pablo Molina said: What else could be causing this? It may be the game itself, RDR2 have some problems @Whiro tag or quote will do the trick i5 3570K @ 4.7Ghz | AsRock Fatal1ty Z77 Performance | Corsair Vengeance 16GB 1600MHz | ASUS Strix GTX 970 OC | Phanteks P400S TG (mesh panel) | EVGA 500W1 | Storage: Corsair 60GB SSD (boot), Gigabyte 120GB SSD, WD 2Tb HDD | Cooling: Custom loop EKWB EK-XRES 140 Revo D5 RGB PWM EKWB EK Supremacy Evo , naked die EKWB EK Thermosphere EKWB EK CoolStream PE 360 EKWB EK Coolstream SE 120 EKWB EK Vardar 120s x6 EKWB EK STC Classic 10/16 x10 EKWB EK DuraClear Tubing 16/10 EKWB EK CryoFuel Acid Green Laptop: Gigabyte G5-KC | i5 10500H | RTX 3060 WHIRO THE FIRST OF DEATH AND DARKNESS He feast on the dead to inherit their power Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 16, 2020 Check other games to see if the problem is insistent. RDR2 is badly optimization and all of the fixes so far just made people even more angry. There's a reason why it got mostly negative when it was first released on Steam. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 16, 2020 Author 9 hours ago, Whiro said: It may be the game itself, RDR2 have some problems 9 hours ago, soluuloi said: Check other games to see if the problem is insistent. RDR2 is badly optimization and all of the fixes so far just made people even more angry. There's a reason why it got mostly negative when it was first released on Steam. Yes, I get this same behavior in GTA V. Happens mostly in games where the GPU is at 100% because of ultra settings. On the other hand, on low usage GPU games it does the same thing, but instead of going from 2000MHz to 6MHz, it goes down from a lower value. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
