I own my Cougar MX-330G case for almost a year now and I couldn't avoid noticing the existence of two slots for fan controllers on the side of the front panel. I wonder if there is a way to populate these slots, what would be very helpful since there are still 3 fans in my pc that use a programmed fan curve. While searching about it I couldn't fin anything, not even in the manual or in forums.
image.thumb.png.6de338a43febb4cfbc2a22ec4b78f683.pngimage.png.d2da0aface68cbb60a18786026e30dbd.png
https://linustechtips.com/topic/1145453-mx-330g-compatible-fan-controllers/
Personally I'd rather my fans be controlled via a fan curve based on PC temps rather than a button on the outside of my case.
Most likely it was a type of slide switch which just controlled the voltage.
https://www.amazon.com/Yohii-20Pcs-Position-Vertical-Switch/dp/B07D51F24B/ref=pd_sbs_328_7?_encoding=UTF8&pd_rd_i=B07D51F24B&pd_rd_r=b0248481-9eb8-43e4-a484-de738325e2a7&pd_rd_w=g3KbU&pd_rd_wg=QYFyQ&pf_rd_p=bdd201df-734f-454e-883c-73b0d8ccd4c3&pf_rd_r=0H0T0FNSSMZD9M9C0ZHB&psc=1&refRID=0H0T0FNSSMZD9M9C0ZHB
(This switch alone will not control the voltage, it was most likely wired to a small PCB board that had resisters on it)
