The Meshify C TG comes in both a tinted and non tinted version, but the mini only comes in a tinted version. The gamers nexus review of the meshify in 2017 kinda implies that the Meshify C and Define C are basically the same case.
So I want to know if the side panel of the Define Mini C is compatible with the Meshify Mini C case. (Or i gues if the front panels are swappable too)
If anyone has any idea, can you let me know?
Side note: It really annopys me that one case series is Mini C whilst the other is C Mini
Edited by rufioh
spelling errror
R5 3600X | MSI B450m mortar max | Gigabyte RTX 2060 mini |  2x8GB 3400MHz (stable at 3600MHz, 16-19-18-19-36, 1.36V, but the XMP profile wouldn't work lol) - https://imgur.com/a/6vMS0lI
https://linustechtips.com/topic/1145342-meshify-mini-c-help/
1 minute ago, rufioh said:
So I want to know if the side panle of the Define Mini C is compatible with the Meshify Mini C case. (Or i gues if the front panels are swappable too)
Yes, if the Define Mini C case is the TG version. I'm not 100% positive but I believe the non TG and the TG versions have different mounts in the chassis.
https://linustechtips.com/topic/1145342-meshify-mini-c-help/#findComment-13215625
Yeah, I'm talking about the TG version of the define and the meshify mini
And thanks so much for the reply
https://linustechtips.com/topic/1145342-meshify-mini-c-help/#findComment-13215629
