Fellow Forum Members,
I want to buy the Bykski Inline Aluminum temp sensor shown in the link below:
https://www.performance-pcs.com/water-cooling/accessories-misc/bykski-inline-aluminum-hd-lcd-thermometer-blue-b-tme-sc-v2-b-tme-sc-v2-b.html
However, it includes a warning which gives me some concern which reads:  "Warning: This component has aluminum that comes in contact with the coolant. You MUST use this in an aluminum compatible loop".
I was not aware Galvanic Corrosion could potentially corrode very expensive components in a loop when I set about  building my loop. My loop has the components listed below. From what I gather I mostly have copper components. I would appreciate any opinions if installing a Bykski Inline Aluminum temp sensor into my loop poses a serious corrosion risk to my loop?
Magicool Radiator (not clear if it is all copper or alunimum):
https://www.frozencpu.com/products/12702/ex-rad-227/Magicool_Extreme_Dual_120mm_Radiator_-_Slim_Profile_LC-RADI240.html
AORUS GeForce Waterforce Waterblock 8G GPU (has a copper base plate)
https://www.gigabyte.com/us/Graphics-Card/GV-N208SAORUS-WB-8GC#kf
Maelstrom V2 reservoir (not clear if it all copper or alunimum):
http://www.swiftech.com/maelstrom-d5-v2.aspx
Apogee SKF Prestige CPU Waterblock (has copper):
http://www.swiftech.com/apogee-skf-prestige.aspx
Lastly, is there a liquid coolant I can use that will prevent Galvanic Corrosion? Thank you for your time.
https://linustechtips.com/topic/1144629-galvanic-corrosion-concern/
Exactly as warning on it states, yes, you shouldn't mix metals in the loop.
Edit: no idea about your radiator (it's probably aluminum so you should probably replace it too) but pump components are likely plastic with anodized aluminum couplers which is safe.
Edit 2: radiator are brass, it's safe to use with copper.
Tag or quote me so i see your reply
Yes you will definitely risk galvanic corrosion with copper + aluminum and there is no fluid that will stop it, just slow it down.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
Anodised aluminium is inert to galvanic corrosion, unless you remove the anodising lair with chemicals or sand paper. but if you want to avoid it altogether use an inline thermal sensor from Thermaltake
CPU: i7 8700K OC 5.0 gHz, Motherboard: Asus Maximus VIII Hero (Z170), RAM: 32gb Corsair Vengeance RGB 3200 mHz, GPU: Asus Strix OC gtx 1080ti, Storage: Samsung 950pro 500gb, samsung 860evo 500gb, 2x2Tb + 6Tb HDD,Case: Lian Li PC O11 dynamic, Cooling: Very custom loop.
CPU: i7 8700K, Motherboard Asus z390i, RAM:32gb g.skill RGB 3200, GPU: EVGA Gtx 1080ti SC Black, Storage: samsung 960evo 500gb, samsung 860evo 1tb (M.2) Case: lian li q37. Cooling: on the way to get watercooled (EKWB, HWlabs, Noctua, Barrow)
CPU: i7 9400F, Motherboard: Z170i pro gaming, RAM: 16gb Corsair Vengeance RGB 3200 mHz, GPU: Sapphire Vega56 pulse with Bykski waterblock, Storage: wd blue 500gb (windows) Samsung 860evo 500Gb (MacOS), PSU Corsair sf600 Case: Motif Monument aluminium replica, Cooling: Custom water cooling loop
yeha... but id not trust that since sometimes the anodision isn't perfect, gets scratched etc. Over (long) time there could be corrosion anyway
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
Dont mix metals. You CAN get away with it if u use a very strong anti corrosive mix, but its not recommended.
Ever flush a car radiator ? especially used cars with multiple owners ?
The coolant comes out brown for a reason, because, on average, many people will just fill their radiator with water. Car coolant systems are a mixture of materials including Aluminium , iron, steal etc. all of which corrode together in the same system.
In a PC loop the 3 metals u should only ever really mix is Copper,Brass, and Nickel, even then u should use a corrosion inhibitor as the nickel plating does eventual fail.
Silver used to also be used commonly as biocide, however that should be avoided if using Nickel plating as that courses nickel plating to fail even quicker.
So .. dont use that flow sensor/indicator.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
