Graphics card lock / hook
11 minutes ago, NorKris said:its a card of 100 grams 1/5 of a graphicscard.. hold inplace at the back.. with no electricity running inside that hook. i cant see any risk what so ever
Three things here are fact.
- It can be done.
- It has been done.
- It can cause issues.
One thing here is opinion.
- I don't believe it's worth it.
I have answered your question, objectively, it can be done. You can find discussions about the subject from multiple locations. I have added commentary that, subjectively, it's not something that I recommend, the extra 15 minutes you're saving (for, again, what is not likely to take place often) is not worth it to me.
You can do what you like with this information and your hardware (you own it after all is said and done) The police are not going to break down your door if you do. I will also not be held liable for any damages that result from it.
