No Power
Go to solution Solved by Mnky313,
6 minutes ago, Bullzy said:
I have tried the paper clip technique
You mean you tried starting the PSU not connected to anything by jumping it with a paperclip?
If the PSU fan doesn't spin it is almost certainly the PSU. You can't really test to see if anything else is causing issues if the PSU doesn't work.
why no dark mode?
Current:
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 1TB WD Blue NVMe SSD
Displays: Internal 1080p@300Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
RAM: 63GB (2x32GB) DDR5 @ 5600MTs
Storage: 2x 1TB Various NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
https://linustechtips.com/topic/1143329-no-power/#findComment-13199387
What I was thinking tbh, have to go down the warranty route now .
https://linustechtips.com/topic/1143329-no-power/#findComment-13199400
