Skyrim Modding
Go to solution Solved by Guest Gazzer96,
A bit old, but it should be the same.
If you cannot be bothered at look at the video, go to http://skse.silverlock.org/ and download the installer for latest current version, then install it where Skyrim is (usually C:\Program files (x86)\games\Steam\SteamApps\common\Skyrim), after that go to that folder, rename TESV.exe to TES_.exe and finally rename skse_loader.exe to TESV.exe. Now mods that use SKSE, like SkyUI, can run on the game.
I have just started modding Skyrim and I was starting with SkyUI and it told me I had to install something called Skyrim Script Extender and when I tried to run the skse loader I get an error saying it can't find TESV.exe. Can anyone tell me what I have to do to fix it?
Dreadnaught: Intel Core i7 970 3.2GHz, Silverstone TD-02, ASUS Rampage III Extreme, Kingston Fury White 24GB 1866MHz, Crucial BX100 250GB + Seagate 2TB SSHD, AMD Radeon Sapphire R9 390 Nitro, NZXT S340 White, Bitfenix Fury 650W, BenQ XL2730Z.
https://linustechtips.com/topic/114299-skyrim-modding/
Try putting the script extender in the same directory as the launch exe for skyrim (which is tesv.exe) and running it there.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/114299-skyrim-modding/#findComment-1527910
https://linustechtips.com/topic/114299-skyrim-modding/#findComment-1527929
Modding skyrim is a pain in the ass, why does no one make quality mod pack for lazy person like me... :(
https://linustechtips.com/topic/114299-skyrim-modding/#findComment-1527948
I agree. I tried some mods but it didn't go so smoothly.
https://linustechtips.com/topic/114299-skyrim-modding/#findComment-1527955
Nexus mods really isnt that much of a pain. Point click and done
Oh the errors, the crashes, AHH...
https://linustechtips.com/topic/114299-skyrim-modding/#findComment-1528036
If you are new to modding. Watch all of gophers videos. He has very informative videos.
https://linustechtips.com/topic/114299-skyrim-modding/#findComment-1528038
I have 132 mods on my Skyrim. To fix if some of them are incompatible I usually just disable them and make a decision on which one is worth keeping.
 Asus M5A99X Evo  - AMD FX-8350 - 16GB Corsair Vengeance 1866Mhz - Corsair 120mm Quiet Edition Fans BenQ XL2411Z- EVGA GTX 980 Superclocked Fractal Design Define R4 - Corsair H100i - 2 TB 7200rpm HDD - Samsung 840 Evo 120GB - Corsair RM750w PSU - Logitech G502 Proteus Core - Corsair K70 RGB MX Red - Audio Technica M50x + Modmic 4.0 - LG 23EA63V x2
Spinthat Spinthat Spinthat Spinthat
https://linustechtips.com/topic/114299-skyrim-modding/#findComment-1528063
Just follow Gopher's guide:
He'll tell you everything you need to know to install 99% of all the mods.
I followed his guide and this is my flawlessly working mod list:
At least, this is what it used to be. Now, I've added about 15 more mods and I'm not getting 60+ fps any more... First world problems!
Intel Core i7-3770k @4.4GHz. 1.170V - Noctua NH-D14 - 8GB (2x4) G.Skill RipjawsX @1866 MHz. CL8 - Gigabyte GA-Z77X-D3H - Samsung 840 250GB - XFX HD7970 DD GHz. @1125MHz - CM 690 II - Seagate Barracuda 2TB + WD RED 3TB - Corsair RM750X
 FiiO E10 - Sennheiser HD 598 - Edifier R1600T - Sony MHC-EX50 - Razer Blackwidow Ulitmate 2013 - Razer Deathadder 2013 - LG IPS237L - Dell P2314H - Philips 237EQPH - LG 47LB561V
 LG G2 - HP Spectre X360 - Audio Technica ATH-M50X - Sennheiser IE 60
https://linustechtips.com/topic/114299-skyrim-modding/#findComment-1528094
