I am going to buy a 650w gold power supply. But people keep telling me to get a 550w cause thats going to be enough. I would have power watts usage around 523w( by calculator without adding any extra watts,its basically the maximum watts being used by my components).
So, I wanted to know that is running a psu at about 100% load is a good thing (by getting a 550w psu) or getting a 650w psu for about 80% load.
My pc specs:
-)Dell T3500 Motherboard
-)Intel Xeon W3530 @2.8GHz(stock not OC)
-) Sapphire Rx 580 nitro+ 8GB Special Edition ( boost clock of 1430MHz)
-) 4*2GB DDR3 Ram
-)SATA 5.9K RPM 500GB Seagate HDD
-)2 2.0 USB
-)Gaming keyboard mouse
I have currently Cooler Master MWE gold 650w fully modular in mind.
https://linustechtips.com/topic/1142467-load-on-power-supply/
That calculator is very wrong
The RX 580 consumes up to around 250 watts when gaming. Should be around 225 watts at stock frequencies, maybe goes up to 250-275w with overclocking.
The Intel Xeon W3530 is unlikely to consume more than 100-120w.
A stick of ram consumes around 2-3 watts, so you're looking at around 10w for ram
The motherboard consumes maybe 20-30w
A mechanical hard drive consumes around 6-8w
A fan consumes around 2-3 watts.
So you're looking at most around 400w on 12v, which means any psu that can supply at least 400w on 12v will be enough. Pretty much any modern 500w power supply can supply 400w on 12v, but if you want to be safe, you can go with 550w.
https://linustechtips.com/topic/1142467-load-on-power-supply/#findComment-13192046
