Overclocking problem
Go to solution Solved by NeuraCode,
Okay I fixed the issue.
  • I reflashed the BIOS from 11 to 3 to 11.
  • I then overclocked the CPU/RAM
  • For some unapparent reason the RAM wouldn't overclock.
  • Reset the BIOS and overclocked again
  • BSOD
  • Enabled CMS
  • Everything works perfectly.
Long story short. This board is stubborn. I can't explain why this happens. It happens that's all I know. It's very buggy.
Hi,
So I have this issue where everytime I start my BIOS settings the BIOS resets. So I have no idea whether I'm still running on 2133Mhz or 3200Mhz like I should. Task manager doesn't show me RAM speed and CMD tells me it's running at 2133mhz.
Things I tried to save the BIOS
  • Only enable XMP
  • Enable XMP and manually overclock the RAM
  • Try different voltage settings while overclocking
  • Disable CSM / enable fast boot
So what RAM am I running at ?
What CMD Says:
What CPU-z Says:
So I noticed that the frequency here is at 1600mhz which I guess is correct. But does that imply it's for both?
I'm really confused, please tell me what my RAM is really running at.
I can't tell what my BIOS says because I everytime I enter BIOS it resets.
I also want to overclock it differently, and my CPU too but no matter what I do the settings simply dont change. Please help me. I'm clueless.
https://linustechtips.com/topic/1141549-overclocking-problem/
DDR= Double Data Rate. 1600x2=3200mhz. What CPU and motherboard do you have?
https://linustechtips.com/topic/1141549-overclocking-problem/#findComment-13184289
Just now, NeuraCode said:
Yeah I know but does the the CPU-Z one give me the correct information?
I'm using a x570 Gigabyte Aorus Elite
Those are JEDEC and XMP profiles, your current memory speed is displayed under Memory tab. As for restarting in BIOS goes you might want to update your BIOS (Be aware doing so though) I saw lots of people having the same exact problem with different ryzen boards so it seems like its related to RAM and board compatibility.
https://linustechtips.com/topic/1141549-overclocking-problem/#findComment-13184327
Thanks,
so I'm running below 2300mhz ...
https://linustechtips.com/topic/1141549-overclocking-problem/#findComment-13184339
Thanks,
yup.
https://linustechtips.com/topic/1141549-overclocking-problem/#findComment-13184342
  • BSOD
  • Enabled CMS
https://linustechtips.com/topic/1141549-overclocking-problem/#findComment-13184786
21 minutes ago, Mister Woof said:
Welcome to the wonderful world of "Ryzen Meets RAM" never a dull moment
Yup, I had the same issue with my Asus board yesterday (b450 mind you, but still). It wouldn't apply any voltage settings for RAM or CPU. Had to downgrade BIOS than upgrade it again to get it to work. No idea why this would matter, but it works fine now...
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/1141549-overclocking-problem/#findComment-13184835
  • BSOD
  • Enabled CMS
Check to be sure the memory voltage is set to 1.35v. If not set it manually.
What cpu and board? Ryzen I assume..
https://linustechtips.com/topic/1141549-overclocking-problem/#findComment-13184844
See... this makes me not want to update my BIOS or OC my ram and leave it right where its at.
Leonidas Specs: Ryzen 7 5800X3D | AMD 6800 XT Midnight Black | MSI B550 Gaming Plus | Corsair Dominator CL16 3200 MHz  4x8 32GB | be quiet! Silent Base 802
Maximus Specs: Ryzen 7 3700x | AMD 6700 XT Power Color Fighter | Asrock B550M-Itx/AC | Corsair Vengeance CL 16 3200 MHz 2x8 16 GB | Fractal Ridge Case (HTPC)
https://linustechtips.com/topic/1141549-overclocking-problem/#findComment-13184904
