3 minutes ago, PCO77 said:
Is there a consensus on thermal paste?
I don't think anyone has made a proper assessment on literally the best paste, but Noctua's NT-H2 is one of the top ones.
https://linustechtips.com/topic/1141387-best-thermal-paste/#findComment-13182971
I'll look into it. I got the mx 4 because it's non conducive electrically and I was afraid of over applying it and getting some on the socket. Thank you for your reply. I'm going to check it out now. I know Noctua makes good products.
Ryzen 7 2700, MSI Rx 5700 Mech OC, Cooler Master V850, MSI B450 Tomahawk, Ballistix Sport LT ddr4 4x16 32gb @ 3200Mhz, XPG Gammix nvme 256gb, XPG nvme 128gb,
https://linustechtips.com/topic/1141387-best-thermal-paste/#findComment-13182981
tbh its hard to get thermal paste in the cpu socket unless you pull of a verge on it lol so i wouldn't worry about that ?
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
https://linustechtips.com/topic/1141387-best-thermal-paste/#findComment-13182984
Ben I'm just a better safe than sorry kinda guy.  You're right though. Thanks again everyone.
https://linustechtips.com/topic/1141387-best-thermal-paste/#findComment-13182996
2 hours ago, Tan3l6 said:
Thermal Grizzly Kryonaut
https://www.guru3d.com/articles_pages/guru3d_thermal_paste_roundup_2019,12.html
Many reviews conclude Kryonaut to be the best non-liquidmetal paste.
This or Noctua NT-2 but these are beating with liquid metal if you can use them... I placed LM on my laptop GPU and CPU that was 5 years old and it has literally brought the old girl back to life, the old Nvidia 870M is a damn hot GPU
https://linustechtips.com/topic/1141387-best-thermal-paste/#findComment-13183904
