Are you a master of installing OS? Then I need your help!
Problem solved
My issues was solved by using Windows Creation Tool to put Windows 10 on a USB stick from a friends Windows 10 computer.
Everything I tried on my Linux system ended in failure.
However I appreciate everyone who has taken the time to message me with their ideas and possible solutions. Cheers.
But If you are having this problem I strongly advise just using Windows Creation Tool before anything else and potentially save yourself a hell of a lot of brain drain and skipping out the very vague windows media driver error on installation. My tip for other people in the future in a similar situation reading this post is that your USB ISO is most probably corrupt or has been written in the wrong way. I think trying Windows Creation Tool is the way to go unless you're trying to install a bent version of Windows 10 on Linux, I would probably check out that Rufus program for that, but you'll still need a Windows computer or a virtual machine running windows I imagine, but luckily I don't need to try that now.
