CPU stuck at .77Ghz
Go to solution Solved by nick name,
Look under your Windows power plan to check that Maximum Processor State isn't set below 100%.
For some reason my CPU has been stuck at .77Ghz. I just got it to fluctuate percentage of use. It won't go above 22% though. Can anyone shed some light on what is happening/a fix? System specs are in sig.
Instructions for frustration management:
1) Sit at desk.   2) Repeatedly slam forehead against desk.
I never said I was smart, just smart enough to be dangerous.
ORLY?
……..'|:::::::,': : : : : : :_„„-: : : : : : : : ~--„_: |'
………|::::::|: : : „--~~'''~~''''''''-„…_..„~''''''''''''¯|
………|:::::,':_„„-|: : :_„---~: : :|''¯¯''''|: ~---„_: ||
……..,~-,_/'': : : |:    ͡° ͜ʖ ͡°) : |: : : :|:  ( ͡° ͜ʖ ͡°)): \..|
……../,'-,: : : : : ''-,_______,-'': : : : ''-„_____|
………',:': : : : : : : : : : : : :,-'__: : : :_',: : : : ;: ,'
……….'-,-': : : : : :___„-: : :'': : ¯''~~'': ': : ~--|'
………….'|: \: : : : : : : : -,„_„„-~~--~--„_: :: |
You have been visited by the propane god, I tell ya hwat. Repost this on 5 more profiles or Hank Hill will bring the propain.
- credit to, @Cinnabar Sonar
https://linustechtips.com/topic/1140664-cpu-stuck-at-77ghz/
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1140664-cpu-stuck-at-77ghz/#findComment-13177459
Newer cpu than mine but fairly similar board.
It hasn’t happened to me (yet) I can make a general opinion.  There may be more specific advice around.
I’m assuming this is a new phenomena.  Cpu is old.  Paste might have given out.  It may have been associated with something either windows10 did when it autoupdated to something broken (this has happened several times with my machine) or that you did when you updated to something broken.  I don’t trust win10 at all lately.  I’m desperately regretting updating to it.
https://linustechtips.com/topic/1140664-cpu-stuck-at-77ghz/#findComment-13177460
How the hell did you know? That freaking wrench monkey struck again!
ORLY?
https://linustechtips.com/topic/1140664-cpu-stuck-at-77ghz/#findComment-13177525
Ancient Chinese secret.
https://linustechtips.com/topic/1140664-cpu-stuck-at-77ghz/#findComment-13177554
