friction sound inside laptop
Igohl
Hi, I need help with my laptop. I've been using this laptop for over 4 years, and suddenly this laptop makes a REALLY loud friction sound. I have tried to clean the fan TWICE, and changed the thermal paste as well, but it does not help at all. Kindly need some idea why this happens. Is this really a fan issue or hard drive failure? Thank you.
https://streamable.com/gqxp5
Laptop spec
MSI GP62 2QE Leopard Pro
4th Gen. Intel® Core™ i5 4210 Processor
NVIDIA GeForce GTX 950M 2GB
DDR3L-1600 MHz 8GB RAM
500GB HDD
Faulty fan bearing maybe? Could try lubricating the fan.
If it was a hard drive failure then the computer probably woudn't boot. You could try replacing the HDD with an SSD anyway, it would at least make your laptop a lot faster.
Those are basically the only moving parts, so it has to be the fan or HDD, and if it still boots onto the HDD then most likely it's the fan.
CPU: AMD Ryzen 5 2600X  |  Cooler: Cryorig H7  |  Motherboard: MSI B450 Mortar  |  Case: Fractal Design Meshify C Mini  |  RAM: Team Vulcan 16GB  3000MHz  |  GPU: EVGA 1070ti Gaming (Kraken G12 Watercooled) |  PSU: Corsair TXM650  |  Storage: Samsung 860 EVO 500GB + WD Blue M.2 500GB  |  Network Card: Asus PCE-AC56  |  Monitor: Acer Nitro VG270U  |  Audio: Sennheiser HD6XX + Schiit Fulla 2
Laptop:
Lenovo s540:  CPU: AMD Ryzen 5 3500U  |  RAM: 8GB DDR4 2666MHz  |  GPU: AMD Radeon Vega 8  |  Storage: 256GB NVME SSD
Other builds:
Workstation 1:
CPU: AMD Ryzen 7 2700X  |  Cooler: NZXT Kraken X62 Rev 2  |  Motherboard: MSI X470 Gaming Pro  |  Case: Corsair Crystal 570X  |  RAM: Corsair Vengeance LPX 32GB 3200MHz  |  GPU: Nvidia Quadro P5000  |  PSU: Corsair TXM750  |  Storage 1: WD Green 120GB  |  Storage 2: WD Blue 1TB  |  Storage 3: Seagate Barracuda 4TB  |  Monitor: LG 27UD68
That sounds like breaking fan. Can be damaged blade or just bearing gone bad. Either way, coming from experience, it will get worse. Only option for laptop out of warranty is to change the cooler yourself. If you can find replacement for it.
Here's lead to start looking at https://forum-en.msi.com/index.php?topic=299273.0
You can ofc take it to local replace shop and ask how much it would cost for them to do it for you.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
