Hey guys! A friend of mine recently upgraded his PC to a Ryzen 5 2600x with 16GB DDR4 3200Mhz on the gigabyte B450M Gaming motherboard. He asked me to do some minor voltage and clockspeed adjustments. Only problem is: I can't change any settings! I can enable XMP wich runs perfectly but all clock/voltage settings are set to auto in UEFI and I am unable to change them. Latest BIOS is installed. I've already reset CMOS and everything. Can anyone tell me what to do? Thanks in advance!
https://linustechtips.com/topic/1140129-need-help-overclocking/
It doesnt let you change it or you don't know how to change it?
Desktop benching:
https://linustechtips.com/topic/1140129-need-help-overclocking/#findComment-13173009
I guess it just simply does not allow manual vcore voltage adjustment with fixed values. AFAIK, offset voltage should be available. I'd only enable PBO and set a -50mV, -75mV negative Vcore offset. And see how it performs.
Life is really challenging. I don't always suceed: )
https://linustechtips.com/topic/1140129-need-help-overclocking/#findComment-13173113
36 minutes ago, Sh3ld0r said:
It doesn't let me. Everything is set to auto and I can't change to manual or enter values or add an offset
with Gigabyte boards you have to use + and - key to change the numbers, did you try that?
Desktop benching:
https://linustechtips.com/topic/1140129-need-help-overclocking/#findComment-13173435
