low GPU usage
By
Blake06
in Graphics Cards
in Graphics Cards
Solved by Mateyyy,
What PSU are you using?
What frequency does your CPU run at while gaming? If it's locked at something around 800MHz, check the BIOS for any power saving settings and disable them. Also try disabling virtualisation/VT-d, also in the BIOS (unless you use VMs frequently).
1
bill well ·
Posted in Peripherals0 -
3
2
Ha-Satan ·
Posted in Networking3 -
1
Beenlucky1 ·
Posted in Cooling4 -
Biermax ·
Posted in New Builds and Planning10 -
potatonut ·
Posted in Troubleshooting7
play_circle_filled
Latest From ShortCircuit:
