22 minutes ago, thebestpopcorn said:
but only have like 165$ what are my best options?
165$ for a gaming PC.....
I don't think so......
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1138744-i-need-help-plz/#findComment-13162869
Ok next question.
What games do you want to play and what do you have to output onto? Need details of the TV.
To buy a PC, monitor, peripherals for that little and get games to play on it too is a stretch to say the least.
You might be better off with a second hand console and games.
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
https://linustechtips.com/topic/1138744-i-need-help-plz/#findComment-13162873
I bought a Xbox One S once for 140 bucks, That may be a option.
CPU: i3-8350k ~ MOBO: MSI Z390 A-Pro ~ GPU: Integrated Graphics (RTX coming soon) ~ PSU: Corsair VS550 (2018) ~ RAM: 2x8GB Corsair Vegenance LPX 3000MHZ ~ Storage: 1xSandisk Plus SSD 240GB
Laptops: HP Probook 6570b (For portable gaming) Dell Latitude ???? (For school)
https://linustechtips.com/topic/1138744-i-need-help-plz/#findComment-13162882
