Help With Wifi and Wifi Settings
Solved by Shahnewaz,
Ah I see. Keep everything as I said, only change the Wireless Mode back to mixed.
39 minutes ago, Shahnewaz said:Wireless Mode: *mixed*
Channel Width: Start with 40MHz and work your way up.
Band Steering: Enabled
DCS: Enabled
Auth Mode: WPA2 only
Encrypt Mode: AES only
ATF Enable: Enabled
Featured Topics
halfbood_drag0n ·
8
AcidVinyl ·
Posted in Graphics Cards3 -
Phantasmagoria ·
Posted in Cooling2 -
BotherRed ·
Posted in General Discussion4 -
2
