How did you fill up a 2TB drive in one day? Is it an SSD? Is the computer only used for gaming or are you storing video files and things like that on it as well?
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1138578-hard-drive-question/#findComment-13161323
It kinda depends as you can pick up cheap Refurbished harddrive from somewhere like ebay! The only problem there is you don't get a warrenty. If you need a drive fast, eBay. if you can wait, save and get one from Amazon, eBuyer or maybe Scan. The later having bundle deals all of the time.
https://linustechtips.com/topic/1138578-hard-drive-question/#findComment-13161329
To check for reviews or check for nice priced drives?
For storage drive reviews I typically use Anandtech and StorageReview.com
For products.. Well that depends on where you are from. But PCPartPicker is generally a good place to start checking.
If you want to know what your drive is filled with, you can either use the built in setting in Windows (Settings > System > Storage > View storage and usage on other drive > choose whatever drive you want to see) or WinDirStat for more detailed info.
https://linustechtips.com/topic/1138578-hard-drive-question/#findComment-13161334
9 minutes ago, Apo3MAX21 said:
I'm new to PC gaming and I just got a new PC for Christmas, and somehow I've already filled up the 2 terabyte hard drive, I'm in the middle of looking for a high space hard drive right now and I was wondering if anyone new any good websites to check.
Amazon and Newegg are fantastic websites to check for hard drives.
Also, maybe slow down on downloading everything under the sun for a bit :)
https://linustechtips.com/topic/1138578-hard-drive-question/#findComment-13161350
