Dual Fan vs Single Fan graphic cards. Which is better?
Tega
I am purchasing a GTX 1660 Super and I can pick between a single fan card or a dual fan card?
What are the Pros and Cons of each ones? Also does a single fan card produce more noise?
Thank you for your answers in advanced.
3 minutes ago, Techno Edition said:
The more fans the better. More air flow. But another factor is the heatsink. If they both has the same heatsink go for the duel fans.
Also having more fans also increase noise output significantly, so if OP has silence in mind less fans is better.
Not necessarily, two fans can run lower rpms keeping same temps as one fan.
   @Whiro tag or quote will do the trick
i5 3570K @ 4.7Ghz  |  AsRock Fatal1ty Z77 Performance  |  Corsair Vengeance 16GB 1600MHz  |  ASUS Strix GTX 970 OC  |  Phanteks P400S TG  (mesh panel) |  EVGA 500W1  |  Storage: Corsair 60GB SSD (boot), Gigabyte 120GB SSD, WD 2Tb HDD | Cooling: Custom loop
                EKWB EK-XRES 140 Revo D5 RGB PWM
                EKWB EK Supremacy Evo , naked die
                EKWB EK Thermosphere
                EKWB EK CoolStream PE 360
                EKWB EK Coolstream SE 120
                EKWB EK Vardar 120s  x6
                EKWB EK STC Classic 10/16  x10
                EKWB EK DuraClear Tubing 16/10
                EKWB EK CryoFuel Acid Green
Laptop: Gigabyte G5-KC | i5 10500H | RTX 3060
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
I disagree, if the heat output is the same and the heatsink is the same, dual fan should spin less than single fan to maintain the same temperature.
The higher noise output gets offset by the better temperatures, so the fans can run in lower RPM and noise level while getting similar temperatures, and there's also the thing that a dual fan card heatsink is most likely going to be bigger so it's going to require even less airflow to achieve similar temperatures, making it even quieter when looking at performance at the same temperature.
