10 minutes ago, SirJACKO said:
i got a new m.2 once installed my old ssd wont show with all my games. when i remove the m.2 the ssd reapairs
When you install an M.2 SSD, your mobo most likely disables some of the SATA-ports. You'll need to check your manual to see which ports it disables and move your old SSD to one of the SATA-ports that don't get disabled.
