I have a Thermaltake view 21 dual tempered case with a x570 motherboard rx590 8gb gpu amd 2700 cpu ddr4 3200 ram. I have everything pretty much I just need help with the intake and exhaust fans I need to buy them asap from Amazon since I have prime rn and I want to get them as fast as possible. Thank you all for the help.
https://linustechtips.com/topic/1137642-need-help-asap-ty/
So, what do you need exactly? Recommendations for intake and exhaust fans?
First of all, I'd recommend assembling the build. It can run for a while without case fans, and while you shouldn't game on it or leave it running overnight if there's no airflow, you can still build it and make sure everything works.
However, the View 21 comes with a pre-installed case fan, so that should be good enough for most tasks unless you plan to run a Prime95 stress test overnight, so you can get your computer up and running right away!
Then, just buy any 120mm case fan from a reputable manufacturer.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/1137642-need-help-asap-ty/#findComment-13154776
Where are you shopping / located? Budget?
https://linustechtips.com/topic/1137642-need-help-asap-ty/#findComment-13154777
On 12/24/2019 at 5:10 PM, GeminiGamer said:
I'm trying to play games that why I need fans. And fans suggestions. Also buying on amazon. USA. Maby like 50-70 for fans wanting cheaper though.
A NF-P12 for rear exhaust and 2x NF-P14S for front intake is hard to go wrong with.
https://pcpartpicker.com/product/VNBTwP/noctua-nf-p12-redux-1700-pwm-708-cfm-120mm-fan-nf-p12-redux-1700-pwm
https://pcpartpicker.com/product/8r9KHx/noctua-case-fan-nfp14sredux1500pwm
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
https://linustechtips.com/topic/1137642-need-help-asap-ty/#findComment-13162365
