Affordable home camera with motion sense and ir light
Wyze Cam v2, plus a micro SD card for the local recording. Some Home Depots stock them, otherwise Amazon. Without the micro SD card you get 7 or 14? days of cloud storage, but they are only 12 second clips and don't re-trigger until motion starts again. So if someone went in front of it and was there for say 4 hours but never stopped moving you would only have one 12 second clip... If you install a micro SD card it will record it all (but only the 12 second clips would go up to the cloud).
Its honestly an amazing camera for $25, you can even flash a different firmware now and get RTSP support to be able to add it to an actual NVR and it still works with the app and Alexa.
For $35 they have a version that can pan left and right, called the Wyze Cam Pan.
