Will my new rig be enough? Help
Solved by Fasauceome,
7 minutes ago, DetectiveSmart said:the 1050 TI I saw was getting around 270 FPS with the games I listed
With a better CPU probably. It's the core 2 duo that's the problem
7 minutes ago, DetectiveSmart said:Again, so this graphics card is supposed to be better?
It's way better.
Assuming you're sticking with the $250 budget, at most $80 will go to the RX 570. That leaves you plenty for a 4th gen i5 and cheap H81 motherboard to go with it, and some DDR3 to toss in as well.
