So I think I have wrong drivers installed on my laptop. The thing is my screen when I turn it on is fine but after a couple of seconds the colors fade and then ultimately leaves a black bar on the lower part of the screen, at first I thought it's and lcd problem but when it's on sleep mode it's fine I can see no cracks or whatnot so I thought it was a display driver problem so I went to amd site because it had a radeon but I couldn't find the driver I'm looking for. Turns out manufacturers name drivers diferent to amd so I just downloaded driver booster and update the drivers there and I think it downloaded the wrong drivers because something pops up saying my drivers and hardware doesn't match. And my touchpad drivers are gone from device manager and I can't do touchpad gestures. So I went to my manufacturers site and use the display drivers they have but It didn't fix anything. Any clue what should I do?
https://linustechtips.com/topic/1136734-wrong-drivers/
did you recently buy it, if so, take it back to the retailer to get it replaced.
if not, just download the touch pad drivers from the manufacturer, then use amd's auto detect to find which driver you need specifically. from personal experience, the monitor black bar thing doesn't sound like a driver issue.
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/1136734-wrong-drivers/#findComment-13147816
1 minute ago, Saint Sushi said:
Okay I'll do that. The black bar thing comes and goes. Sometimes it has it and sometimes it doesn't. I've had this for 3 years now so the warranty has expired already. When I turn it on the screen is fine and gradually fades to this
oh that's clearly a damaged lcd, either water or just wear from trauma.
https://linustechtips.com/topic/1136734-wrong-drivers/#findComment-13147827
Just because a screen is not cracked doesn't mean it isn't damaged....
https://linustechtips.com/topic/1136734-wrong-drivers/#findComment-13147854
13 hours ago, Saint Sushi said:
Yeah that's what I thought. I didn't know because it was fine a couple of days ago
One thing with newer electronics is that they work until they don't. Sorta like a light bulb is either on or off. Something as small as a cable being loosened because you dropped it 3 cm can cause the whole machine to break down.
https://linustechtips.com/topic/1136734-wrong-drivers/#findComment-13149440
Before I check if it's the hardware is the issue I'm planning to format my laptop. Is there any discernable risk/downside/caveat on doing so?
https://linustechtips.com/topic/1136734-wrong-drivers/#findComment-13149540
Backup your data first, at least the stuff you need. Otherwise it's gone.
[Intel i7 7700K 4.9GHz][Corsair Vengeance LPX 32GB 3000MHz][EVGA GeForce GTX 1080Ti 2100MHz][Samsung 970 Plus 1TB][Samsung Evo 850 1TB][ASUS Hero Maximus IX][EVGA Supernova 1000W G+][Rosewill Cullinan]
https://linustechtips.com/topic/1136734-wrong-drivers/#findComment-13149615
Barely got anything that I need in it. I transferred it because I can't use it for anything. I'm just worried that formatting might cause some problems
https://linustechtips.com/topic/1136734-wrong-drivers/#findComment-13149684
It shouldn't. Hopefully you still have your Windows install disk and all of that stuff?
https://linustechtips.com/topic/1136734-wrong-drivers/#findComment-13149700
Just be aware though, formattting isn't going to fix your screen. It looks like that screen is toast. You can look online, I'm sure you can get a replacement panel.
https://linustechtips.com/topic/1136734-wrong-drivers/#findComment-13149702
Really? Dang. I was hoping that it's fine because at time I could still see colors past the black bar. It only goes black after a couple of minutes. Where can I find my panel product number?
https://linustechtips.com/topic/1136734-wrong-drivers/#findComment-13149909
