Help! No that I am done with my friends PC building I need an upgrade. I have a very old computer that I hate to admit but it was a prebuilt but I have not had the budget to improve so I was thinking to get a new one for around 1k but I realized that I don't need to heavy of a load so I could just upgrade. At the moment I have a Lenovo ThinkCentre M81 (https://www.cnet.com/products/lenovo-thinkcentre-m81/) what would you change to improve so I can play stuff like overwatch and dauntless at like 40+ fps.
Edit:for under 300 $ can. Also possibly able to run vr (def not needed)
https://linustechtips.com/topic/1136659-help/
throw that trash in the junk, I wouldn't even bring the power supply to a new build.
try something like this
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/1136659-help/#findComment-13147320
But couldnt we just replace the power supply and gpu because a i5 aint that bad
https://linustechtips.com/topic/1136659-help/#findComment-13147383
Some games barely run on 4th gen i5, this pc would run for around $80 as a refurbished, it's ridiculously under powered for titles coming out today. A ryzen 3 apu built for $300 will outperform this machine.
the headache of upgrading this, especially since it's a prebuilt from toshiba, it's not worth upgrading. I speak only for your sanity.
https://linustechtips.com/topic/1136659-help/#findComment-13147402
But on linuses new christmas shopping or gift list or whatever its called he uses an i3 and runs triple a games
https://linustechtips.com/topic/1136659-help/#findComment-13148609
yeah but 9th gen i3 outperforms 7th gen i7. your platform is just too old. amd forced intel to innovate, meaning that everything 7th gen and older is more or less a dead platform in terms of worth to upgrade. and it's worse in your case cause it's a prebuilt.
https://linustechtips.com/topic/1136659-help/#findComment-13149074
Look for used parts but, go for a new PSU
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1136659-help/#findComment-13149799
LOL, That ain't true.
Even x58 xeons (which are available for around $20-30 on eBay) can crush your so called "9th gen i3 processors" in workstation tasks despite being a decade old.
4th gen Intel processors are completely fine. They even support the latest avx 2 instruction set.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1136659-help/#findComment-13149808
And to answer your question, I'll recommend upgrading to a i7 2600. They go for around $50-70 in the used market. You'll have to update the bios to the latest available one in order for it to support the i7.
I'll recommend a rx570/580 for the GPU side of things. Rx570 goes for around $70 on eBay while the latter goes for around $100.
PSU looks like a standard atx power supply with standard 24pin power connector. So any standard size PSU can be used. I'll recommend a cx550 from corsair. They go for around $50.
I'll also recommend adding another 4gb stick of ram. 8gb of ram is kind of staple these days.
Also, yes this rig would be able to play those games at 60+ fps in 1080p.
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1136659-help/#findComment-13149837
  • 3 weeks later...
Thanks ? . But also dauntless cant go past 15 fps on this machine but i will look into what you suggested
(edit: i just realized you meant the rig u suggested sry)
https://linustechtips.com/topic/1136659-help/#findComment-13207812
