Installation problem... :(
Go to solution Solved by spartaman64,
amd created the x86-64 instruction set so many developers call it amd64 but it runs on any x86-64 cpu
I wanna install Windows 7 on my rig. My Motherboard: GIGABYTE Z97X Gaming 7 Rev 1.0
I was just downloading the drivers from the original manufacturer page and I came across this file right here:
marvell preinstall driver
It's some SATA controller stuff that has to be loaded before Windows 7 Installation. When I checked these files, I saw two folders in it:
- amd64
- i386
My CPU is x64 and I'm gonna install x64 version of Windows 7 ofc. Since I know x86 means 32 bit I'm guessing the "i386" is the 32 bit folder and the other one is 64 bit and I need the 64 bit one. But why does it say "AMD64"? I don't have any AMD components in my PC. I only got Intel and NVIDIA. My cpu is Intel i5-4460.
Can anyone help? Should I install this thing?
https://linustechtips.com/topic/1136244-installation-problem/
Why would you install windows 7 when security support for it ends in a month?
CPU: Ryzen 5 5600x  | GPU: GTX 1070 FE | RAM: TridentZ 16GB 3200MHz | Motherboard: Gigabyte B450 Aorus M | PSU: EVGA 650 B3 | STORAGE: Boot drive: Crucial MX500 1TB, Secondary drive: WD Blue 1TB hdd | CASE: Phanteks P350x | OS: Windows 10 | Monitor: Main: ASUS VP249QGR 144Hz, Secondary: Dell E2014h 1600x900
https://linustechtips.com/topic/1136244-installation-problem/#findComment-13143698
Only security support?? :D
Everything is ending and dying.
The time has come to say bye bye Win 7, you served very well!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1136244-installation-problem/#findComment-13143713
There is a third party patch available to gain extended win7 updates. Problem is that MS can close it everday since you do not pay for the extended support
https://linustechtips.com/topic/1136244-installation-problem/#findComment-13143725
Because I don't like Windows 10 and chances are, I'll never like it. When Windows 10 will be the last working OS that's left, I'll switch to Linux and I'll use Wine to emulate Windows games or I'll simply stop playing PC games. Windows 10 is utter garbage (that's my own personal opinion, don't feel attacked please) and therefore I'll avoid using it.
https://linustechtips.com/topic/1136244-installation-problem/#findComment-13145180
i am also a big fan of win 7 over win 10. nothing was improved, it is from my experience less stable than my win 7 builds. the start menu and the stupid tablet and touch options are not even useful on a desktop or even a laptop.
https://linustechtips.com/topic/1136244-installation-problem/#findComment-13145259
