Help me to decide please
Solved by Midnitewolf,
AIO in the 240mm-360mm range mounted in the front of your case could drop your temps by about 15-20 degrees give or take. AIO in top of case tends to give about as much cooling performance as Air, maybe a few degrees better. Good Air cooler can drop your temps by 7-10 degrees. 7-10 degrees would probably give you about 1-2% better performance, 15-20 degree gets you maybe 3-4% more performance. None are needed as the included cooler is just good enough to do the job. The rest is up to you to decide if it is worth it to change out to a different cooler.
