So I'm currently running an i9 9900k @ 4.80GHz / 1.275vcore and an EVGA 1080 Ti SC2 @ around 1900MHz / stock voltage.  The pump on my Fractal Celcius S36 I had on the 9900K appears to have died.  I decided to take this opportunity to dip my toes into the custom-loop waters.
Will this prebuilt kit https://www.ekfluidgaming.com/ek-kit-a360g be enough to cool a 9900K + 1080Ti?  I'm having a hard time reading EK's literature to find any "Rated TDP" for this system.
(shoutout to Fractal Design's support team.  Provided them a proof of purchase and they OVERNIGHTED me a brand new Celcius S36 cooler.  Which I plan to just EBAY since its a brand new, unopened product)
https://linustechtips.com/topic/1135564-first-time-custom-loop-experiment-advice/
Take what I say with a grain of salt since I’ve never done a custom loop, but I would go with standalone rads for each the CPU and GPU
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
The 360mm rad that the A360G comes with should be plenty enough to cover a 9900k and a 1080ti, assuming that it has respectable airflow through it.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
Thanks for the info man,  I'm certainly hoping so.
WORST CASE scenario it looks like their Liquid Gaming Expansion Kits are relatively cheap for an addon 240mm rad if needed.
It really shouldn't be necessary under any normal conditions, but it is an option I suppose.
I'm running a 4790k (1.2v 4.5 all core) and a 1080ti on a 280, in a case that has "good enough but not fantastic" (rough quote from Steve over at GN) airflow (Evolv X) and I'm positive that I have overhead in my current loop.
Add another ran. Unless you like more fan noise and speed.
360 is never enough.
What kinda CPU and GPU temps do you get w/ that loop?  My 9900K is a bit of a dud (it does 4.80GHz @ 1.270vcore all day but requires 1.310vcore just to do 4.90GHz so 5GHz is realistically off the table).
Well...the EK A460G Kit is already in shipping.  I think I'll try my luck with this, first, then look at expanding w/ another 240mm if i really need to.
This is only the 2nd PC I've ever self-built and now this will be my very FIRST time doing a "custom loop" so I wanted to go with this premade kit to keep things as simple as possible.
If I end up liking it I can go with a more traditional loop next PC build a few years out from now!
Thanks for all the tips guys!  Appreciate it!
Under a real-world workload, my temps top out right around 50° ΔT over ambient with my front panel on. Removing the front panel can knock that down ~5°, this is with a fairly conservative curve however, with my fan curve only hitting 100% at 79°c (which during winter months, I rarely hit)
Under Synthetic load, I can push it to ~70-80°ΔT over (you'll have to forgive me for that range, it's been a number of years since I pushed her that hard), but that's after an extended runtime of something intense such as linpack. That would mean numbers that throttle during summer months
It's been a hot minute since I monitored my GPU temps (pun possibly slightly intended), but I remember them being in the mid-60°'s for the core, slightly higher for the VRM's, and that would have likely been tested with Destiny 2, some time around the Forsaken expansion, Similar ΔT as the CPU.
When it comes to a dud, I can say I'm there with you, in a little bit of a strange way. I've been stable at 1.2@4.5 (which is a slight undervolt with a slight overclock from what stock tries to push) all core for several years, but I can't get 4.6 stable at anything that I've tested, clear through to 1.295v, and I'm not really comfortable going any higher,
Go big or go homeeeeeee ❤️
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
K well this sounds rather promising.  9900K definitely pulls alot more power than a 4790K but at the same time I'll have a 360 rad over your 280.  Is there ANY chance I could bother you to run a quick stress test (literally 1 or 2 minutes) and monitor the peak wattage your CPU pulls? (via HWMonitor or HWINFO).
I know my 9900K pulls around 225W fully-synthetic and around 150W when playing a stressful my game (but generally closer to the 100W range).  And my 1080Ti seems to pull around 250W max as well.
Thanks again my dude!
I'm not home at the moment, I will when I get the chance though.
From memory, I remember linpack pulling a max of somewhere around 91w, I don't have number on the GPU. I don't know that you can compare apples to apples in this situation, as power delivery has changed a lot since fourth gen AFAIK, you'd need someone who knows CPU architecture and/or more general knowledge on the subject to inform you if this is actually the case though.
Right on.  Well thanks for all the info man.  My EK Kit arrives tomorrow or Thursday, so I'll find out soon enough anyways I suppose!
A five-minute linpack (OCCT) capped out at 92.31w, with an average of 88.81w. (with margin of error for the ~10 seconds at idle before OCCT was initialized and operating)
A run-through of Superposition (1440p, DirextX, fullscreen, extreme shaders, high textures, DoF on, Motion blur off, for what it's worth) produced a max of 265.51w, with an average of 249.83w (with margin of error for the ~10-15 seconds at idle between starting HWiNFO and Superposition loading in and beginning the benchmark)
Again, though, I do not know if this is an apples-apples comparison between generations.
I also can't validate that HWiNFO is entirely accurate.
My temperatures were well within expected range, but are largely useless for comparison as my loop hasn't had time to reach equilibrium and exact ambient temperatures are not recorded (I've come to the realization that I don't own a thermometer other than the one coupled with my HVAC unit, so room ambient is approximate).
(Rough ambient of 13°)
  • CPU capped out at 49° (five minute run)
  • GPU capped out at 53° (three minute run)
I have a Titan X (980Ti) and 7600K, both overclocked, running on a 240mm radiator with 1500rpm? fans.  The water gets up to about  45-50C under synthetic load (both CPU and GPU maxed out...doesn't really happen in the real world)
360mm is fine.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
