Where you download DS4Windows?
11 minutes ago, Randomizer23 said:
Hey guys I wanted to play Shadow of the Tomb Raider with my PS4 controller. I turned off steam input and am using the controller wirelessly through DS4 Windows. The buttons in game show up as xbox not ps4 is there a way I can change this?
I don't think so.
Since DS4windows "simulates" the use of XBOX controllers...
6 minutes ago, Randomizer23 said:
idr. When I plug it in with a usb and dont run DS4 windows it works but as soon as I connect it via bluetooth it does not work.
Do you have this option?
I guess you're using Jays2King version which already discontinued. Remove that and install from Ryochan7 fork.
https://ryochan7.github.io/ds4windows-site/
Regarding Bluetooth, which driver you use for your bluetooth dongle?
Just now, xAcid9 said:
I guess you're using original Jays2King version which discontinued. Remove that and install from Ryochan7 fork.
I didnt use a dongle. I an using my motherboards built in wifi its the Aorus ultra Z390. I did not install anything else. Also something weird is happening now it says driver error in windows bluetooth under the controller.
Can you take screenshot of that? ? Bluetooth compatibility with DS4 is kinda iffy.
Try install driver from Ryokan7 DS4Windows.
and then reboot.
maybe change profile name to ps4
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Canon 7D MK2 - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, GoPro hero 6 black
Dead cameras: Nikion s4000, Canon XTi
Pc's
Towers:
Main Dell optiplex 5050 "Bandog"  - intel i7-7700 - nvidia t400 4GB - 20GB ram - 1TB Samsung 990 Pro heat sink - 256GB Samsung 850 - 5TB HDD
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 16GB ram - 1TB HDD
Laptops:
main laptop "Soppo": Lenovo P14s Gen 5 - Intel ultra 5 135H - Nvidia 500 ada - 32GB ram - Samsung 990 pro 1TB
Secondary/radio programming laptop "Klukai": Dell Latitude 5430 - Intel i7 1185G7- 16GB ram - Kioxia BG6 256GB
Tertiary/Networking/radio programming laptop "Persica": Dell latitude 5414 Rugged - intel i5 6300u - 12GB RAM - Samsung 870 EVO 500GB
Any questions? pm me.
#Muricaparrotgang
