All the 780ti's.
I would recommend this:
CPU:  Intel Core i7-4770K 3.5GHz Quad-Core Processor  ($339.99 @ Newegg)
Motherboard:  ASRock Z87 Extreme6 ATX LGA1150 Motherboard  ($158.49 @ Newegg)
Memory:  Crucial Ballistix 16GB (2 x 8GB) DDR3-1600 Memory  ($179.99 @ Newegg)
Storage:  Samsung 840 Pro Series 128GB 2.5" Solid State Disk  ($114.99 @ Amazon)
Video Card:  EVGA GeForce GTX 780 Ti 3GB Video Card (2-Way SLI)  ($717.55 @ Newegg)
Total: $2651.52
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-09 17:45 EST-0500)
You can probably get better stuff, but this is just something that I threw together really quick
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1516420
Read before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
This belongs in the New Builds and Planning section. I'm moving the thread.
Please post in the correct sub-forum in the future.
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1516430
Can someone recommend a "Gaming pc" parts :)
my budget is 3000$
tnx
Not to steal what @TheDoubleYGamer is doing but if you check my rig its for mining and gaming and its $2,500 check the link in my signature
My n00Build http://pcpartpicker.com/user/NameOfNoInterest/saved/
Do you really expect me to know things?
$25.67/$~2500 (Price changes hourly..) I'm 1/100th of the way there!
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1516431
All the 780ti's.
Total: $2651.52
for a 3k build I would invest in a better cooler.
Error: 410
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1516451
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($229.29 @ Amazon)
CPU Cooler:  Corsair H100i 77.0 CFM Liquid CPU Cooler  ($89.99 @ NCIX US)
Motherboard:  Asus Maximus VI Hero ATX LGA1150 Motherboard  ($189.99 @ Newegg)
Memory:  Kingston Beast 8GB (2 x 4GB) DDR3-2133 Memory  ($89.98 @ PCM)
Storage:  Samsung 840 EVO 250GB 2.5" Solid State Disk  ($174.99 @ Amazon)
Video Card:  EVGA GeForce GTX 780 Ti 3GB Video Card (2-Way SLI)  ($765.76 @ NCIX US)
Case:  NZXT Phantom 530 White ATX Full Tower Case  ($99.99 @ Microcenter)
Operating System:  Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($84.99 @ NCIX US)
Total: $2810.72
(Generated by PCPartPicker 2014-02-09 17:58 EST-0500)
Specs
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1516506
Why 7 over 8?
You'll see better performance with 8.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1516818
Are you planning to sli?
No point getting such an expensive cpu cooler or an i7 over an i5 when what you're doing is gaming.
Why such an expensive motherboard?
Dominator platinums are a waste of money. Get some cheaper ram.
WD Blacks aren't worth the money for anything but the warranty. Barracudas are quite cheaper and only slightly slower.
The 780 ti is a bad value. I'd suggest getting a 780 or 290 instead.
Why such a large case? What are the 3 fans for?
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1516904
nope
u guess.. i just like the 100i
because i really liked it when linus unboxed and i just think it's the best one.. of course there are cheaper and maybe better i just like this one lol
yea but the lightning effect that it has and i guess the fact that linus uses them in all of "high and" pc builds is also the reason
wd blacks aren't but i have one in my pc and i wolud just be adding this one to the build
maybe but in the long run little better.. i'm kinda thinking 3+ years before buying a new one so why not go all the way
because i generally love coolermater cases and the fact that the haf x is the only case that can measure to the 900d and it's easier to fill it up whit parts
one forthe back exhaust, 2 for the h100i replacement
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1516946
nope
The psu is very much overkill if you don't plan to sli. A decent 600w is already plenty.
Are you getting the motherboard just for the looks? Btw, the only point to get a more expensive motherboard is for the build quality and the features. If you're not using the features, it's just a waste of money like buying something you never use.
Ram is ram. Brand does not at all affect performance. You're spending ~$260 more on the the looks of the ram alone with dominator plaitinums.
Are you saying you already have the 4TB hdd?
'Going all the way' is not what you're doing. Going all the way would be to get a 4960x and 4 780 Ti's in sli. What you're doing is just spending more than you need and not getting that much performance for your money. It's better to spend less and get what you need to use the extra money to upgrade more often.
Such a large case will look awkward being so empty. A smaller case would be more suitable to make it look more complete with less parts.
A NF-S12A would be more suitable for rear exhaust. As for the cpu cooler, something like a 212 Evo is much cheaper and will provide ample cooling for a gaming cpu oc.
This would be my recommendation: http://pcpartpicker.com/p/2QnVH
and to save the extra money for upgrades as you need it and better/cheaper parts come out.
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1517038
No of course not just for the looks.. i plan to overclock the cpu and ram.. and it has a lot of hdd/ssd ports
i know .. i could get corsair vengeance 16gb for 165$ but.. i like the platinums.. it feels.. "platinum" heh
i have a 2T green wd ... 80% full
good point.. i have about a month to decide.. il let you know :)
i have a Coolermaster HAF 912 Plus and i could fit all this in to it but i guess the first time I saw the "Haf X" i just wanted it.. don't know why..
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1517105
And for the psu .. i know.. but it's Modular, it has the corsair link thing, it has the low rpm and it's slick looking...
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1517134
There's little to no point to oc'ing ram. It just takes up more power and raises instability when what you're going for is gaming performance.
As for oc'ing, the 212 Evo is plenty for an ample gaming oc.
How many drives are you planning to use?
I'd suggest planning later then. ~2-3 days at most before you buy. Parts and prices change frequently so any parts list you come up with now will likely be obsolete by the time you're ready to buy.
It sounds like you're getting parts just because you feel like it instead of just getting parts to make a good system or one that looks nice. Expensive and premium parts and nice but I can tell you it's far from guaranteeing you that you will have a nice looking rig and that you will likely look back and facepalm at your waste of money of a build.
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1517140
Corsair link is just a gimmick more than anything else imo.
What I recommended is semi modular which only has the cables you will need to use anyway preattached. The capstone looks more slick imo with no blatant labeling on it.
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1517148
"As for oc'ing, the 212 Evo is plenty for an ample gaming oc." i know.. but i have a air cooling tower now and i just wanted to try the watercooling..
true.. i managed to fry my ram once lol
the one that i have and the 4t one that i'm gonig to by for the files and the ssd for the boot and 1-2 applications..
that is actually true lol.. it's like my dream machine but yea i would probably facepalm after like a month ..
I'll look in to the psu thing.. i have time to decide on that .. thats like the easy part lol
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1517276
If you want to, go ahead.
Also, the heatsinks on ram don't do much to help cooling anyway even for oc'ing. Memory generally doesn't get that hot at all.
The 3TB drive has more gb/$. If you want more storage, I'd just grab more 3TB drives.
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1517311
i will not.. that's just my dream..
i know.. for me it's more for looks than anything..
btw for the cooling i'm also considering "Be Quiet DARK ROCK 2"
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1517339
Why 7 over 8?
Some people don't like the UI with windows 8 and find it easier to continue using 7 (if they've previously used it) rather than switching to 8. I think windows 8 is more suited to tablets/touch devices than desktop PC's.
mudgee - Jedi System Builder
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1517362
Two more things..
1. Win 7 or 8
2. Kingston HyperX 3K 240GB 2.5" Solid State Disk .. yes or no ?
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1517443
Two more things..
1. Win 7 or 8
1. Whichever you prefer. If you don't care, Windows 8 is better.
2. It performs noticeably the same to the one I suggested and is quite a bit more expensive.
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1517456
btw for the cooling i'm also considering "Be Quiet DARK ROCK 2" ?
Yeah, that's fine. You'd need a case that supports taller cpu coolers like a Define R4 or Arc Midi R2 though.
The Dark Rock 2 is 166mm tall and the N600 only supports coolers up to 160mm tall.
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1517470
One more thing .. for gaming.. is the 4670k better then the 4770k.. I mean the + for the 4770k is that it has hyper threading but let's be honest.. games don't
use cpu that much..
https://linustechtips.com/topic/113500-gaming-pc-parts/#findComment-1517513
