best performance or best value?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1134592-best-itx-mobo/#findComment-13130028
https://linustechtips.com/topic/1134592-best-itx-mobo/#findComment-13130029
2 minutes ago, Hendricks3 said:
gimme a best performance and a best value also i like to dab on o'c
cheapest board atm, has decent enough headroom to OC a 6 core pretty decent
https://pcpartpicker.com/product/ZGDJ7P/gigabyte-b450-i-aorus-pro-wifi-mini-itx-am4-motherboard-b450-i-aorus-pro-wifi
this one's technically mini dtx but fits most ITX cases
https://pcpartpicker.com/product/skLwrH/asus-rog-crosshair-viii-impact-mini-dtx-am4-motherboard-rog-crosshair-viii-impact
Primary PC:
PSU tier list
https://linustechtips.com/topic/1134592-best-itx-mobo/#findComment-13130036
B450i MSI Gaming Plus AC above is best you'll get (assuming in NA, as prices could swing in different region) for cheap, should be good for 8 core OC, If you don't wanna step up to about 220$ x570 ITX. If you did go for x570 ITX though pretty much all of them have insanely good, 10/10 VRMs, sometimes better then standard ATX x570s at same prices, just choose one with features or price you are looking for.
https://linustechtips.com/topic/1134592-best-itx-mobo/#findComment-13130045
Just now, Otto_iii said:
B450i MSI Gaming Plus AC above is best you'll get (assuming in NA, as prices could swing in different region) for cheap, should be good for 8 core OC.  If you don't wanna step up to about 220$ x570 ITX. If you did go for x570 ITX though pretty much all of them have insanely good, 10/10 VRMs, sometimes better then standard ATX x570s at same prices, just choose one with features or price you are looking for.
i know its a good mobo i currently have it in my htpc i thought maybe there was a better one for the same price
https://linustechtips.com/topic/1134592-best-itx-mobo/#findComment-13130051
No one can really match the MSI B450 ITX board for the same price
Desktop benching:
https://linustechtips.com/topic/1134592-best-itx-mobo/#findComment-13130157
