Tripple Monitor - Display Port Injection
Solved by LyondellBasell,
22 hours ago, VisualProcessor said:Is it possible to inject three display port signals into one thunderbolt cable? I am having a hard time finding a 3 input (display port) 1 output (thunderbolt) pcie card.
Is this something thats actually done? or do I need one thunderbolt per display port?
22 hours ago, AbydosOne said:Hypothetically... you could put one of those DisplayPort Multi Stream Transport splitters on the far end, and that might allow for three DP streams. But I don't know much about DP and Thunderbolt together.
Displayport MST hub would be the closest thing that exists, but I'm not sure what it really buys you.
Unless you have some sort of limitation that prevents you from running multiple cables, discrete cables is the way to go.
