meh get the h105 or h110.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515360
Go for a 780ti instead of dual 770s (Imo single card is better than dual) also you could get a 760i for corsair link
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515366
4gb vram wouldn't hurt for sli.
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515388
What's with the RAM? The Vengeance Pro series ram have some of the worst timings on the market. I'd opt for G-Skill tridents, since you can get DDR3-2400 16gb for cheaper than the one you have selected.
Also, why not just spend about 50 dollars more towards your graphics card and get a 780ti? SLI doesn't always scale well in games, and you're better off getting a higher end single card now, and being able to upgrade in the future by just throwing in another card.
EDIT: You said you were running a single 770 for the start, in that case, you should be okay.
As for the PSU, you should be alright. Sure, you are 100w over what you'll actually need, but it could save you some room if you ever decide to make some upgrades (new processor in the future, etc).
Just some thoughts.
//CCap
//ccap
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515391
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($229.29 @ Amazon)
CPU Cooler:  Corsair H105 73.0 CFM Liquid CPU Cooler  ($108.10 @ NCIX US)
Motherboard:  Gigabyte G1.Sniper Z87 ATX LGA1150 Motherboard  ($174.98 @ SuperBiiz)
Memory:  PNY XLR8 16GB (2 x 8GB) DDR3-1600 Memory  ($129.99 @ Amazon)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Disk  ($99.99 @ Microcenter)
Video Card:  EVGA GeForce GTX 780 Ti 3GB Video Card  ($699.99 @ NCIX US)
Case:  Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case  ($99.99 @ Microcenter)
Operating System:  Microsoft Windows 8.1 - 64-bit - OEM (64-bit)  ($99.98 @ Best Buy)
Total: $1909.80
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-09 14:51 EST-0500)
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515395
Why so much ram?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515397
bigger ssd, like 250gig. H100i might be a tight fit but it will still fit.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515411
What's the system being used for? Why sli?
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515413
Just some thoughts.
//CCap
what about kingston hyperx ram?
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515440
Brand of ram doesn't matter.
main use is for gaming
sli will be in the future, will run single 770 from the start
What's your budget? You could get better for the money.
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515445
1700-2000$
Better: http://pcpartpicker.com/p/2Qd0O
My actual recommendations: http://pcpartpicker.com/p/2QcVO
Save the rest of the money for upgrades.
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515487
Hi guys
im planning to build this rig in the next couple of weeks
what do you think?
http://pcpartpicker.com/p/2QcbK
Here's what I would suggest
Powerful now, below budget, should be fairly quiet, and plenty of room for expansion and upgrade.
http://pcpartpicker.com/p/2QdjW
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Core i7-3770K 3.5GHz Quad-Core Processor  ($314.99 @ Amazon)
CPU Cooler:  Noctua NH-D14 65.0 CFM CPU Cooler  ($74.98 @ OutletPC)
Motherboard:  MSI Z77A-G45 Gaming ATX LGA1155 Motherboard  ($134.98 @ SuperBiiz)
Memory:  A-Data XPG V2 16GB (2 x 8GB) DDR3-2400 Memory  ($147.27 @ TigerDirect)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Disk  ($89.99 @ Newegg)
Storage:  Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($82.50 @ Amazon)
Video Card:  PNY GeForce GTX 780 Ti 3GB Video Card  ($669.99 @ Microcenter)
Power Supply:  XFX ProSeries 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($129.99 @ NCIX US)
Operating System:  Microsoft Windows 8 (OEM) (64-bit)  ($97.98 @ OutletPC)
Total: $1842.66
(Generated by PCPartPicker 2014-02-09 15:14 EST-0500)
you can change the RAM and CPU cooler if you'd like. 2x8 slot kit will give you upgradability, as will a 780TI and 850w PSU. There's money left over so you could buy a larger SSD if you'd like.
Edited by helping
Error: 410
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515517
Total: $1842.66
but will only run single card in the start
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515550
Less heat, less noise, less power.
Buying two 780's will give you more raw performance now, but buying a single 780TI and then SLI as an upgrade in the future will give you more performance then. If you were to buy two 780's now, when you want to upgrade in the future you'd have to do either 3 or 4 way 780 SLI (imo, no) or throw them out all together.
There's nothing a 780TI can't handle today.
I always try to build a system that can be upgraded and conscious of the future.
Error: 410
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515569
but why z77
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515610
but why z77
whoops, my mistake.
updated
http://pcpartpicker.com/p/2Qene
CPU:  Intel Core i7-4770K 3.5GHz Quad-Core Processor  ($334.29 @ Amazon)
Motherboard:  MSI Z87-G45 Gaming ATX LGA1150 Motherboard  ($139.99 @ Newegg)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Disk  ($89.99 @ Amazon)
Total: $1866.97
(Generated by PCPartPicker 2014-02-09 15:39 EST-0500)
Error: 410
https://linustechtips.com/topic/113426-new-build-help/#findComment-1515659
